I was up in the loft yesterday looking for something the missus was after, and I spied a gig bag in the corner that I'd forgotten about.
Decided to bring it down. I thought
@HarrySeven might like to see some pics actually - the acoustic version of your kind of thing I reckon mate!
This was my very first proper guitar. It was given to me by my aunt, and she bought it from new. I think it's about 1973 or so. She's sadly no longer with us - so this has all sorts of special meaning to me. First guitar. Given to me by a much loved family member who is no longer with us. Played my first gig with it, wrote my first song on it..
It's a 000 bodied Kay KDG-77. Made in Japan in the days when the Japanese guitars were so well built to compete with the American market.
Ok, so its not particularly spectacular, and neither is it particularly collectible. But it's going nowhere!
I've been thinking about getting it back into playing condition. I'm concerned about it's fragility, so I need some really nice light strings for it - any suggestions? Also, the tuning knobs are getting loose - a couple are cracked and under tension slip on the pegs - any suggestions here also greatly appreciated..
There's no bridge/soundboard lift or sink so it's basically sound. Binding is all still fine as well.
It's an old friend. I'm glad I dug it out of the loft. It doesn't deserve to be up there.
You can fix the machineheads easily if you can find a set of other ones with the same spacing between the 'hooks' - just undo the gears and you can replace the key shafts. What's the exact distance between the inside and outside edges?
If the top hasn't pulled up I wouldn't be worried about fragility or stringing it too light - these are actually pretty robust guitars and were always intended to be strung with at least 12s, that's what acoustics were like back then! 12 was "light" gauge .
Also not sure where I might get replacements from..
I've replaced literally hundreds, both individually and as full sets. You just need to remember to slacken the strings off first or removing the gear can be amusing .
I may even have spares, but if not and we know the size then any set of modern classical heads with similar keys that fits will do the job - or if you swap the rollers for the metal posts from your set you can use the whole strips if you need to. The mounting screw spacing is the only issue, and these look fairly standard. Classical-type tuners with metal posts aren't common usually.
I'd like to get it up and running again. Despite the age and undesirability it really is a super playing and sounding acoustic. I think I've even got an old track from a previous folky band somewhere with it recorded on!
To be fair, we haven't been in this house long, and I put it up there out of the way whilst we did some decorating and other stuff.
I, er, might have forgotten about it.. *ahem*
Went up today, saw it, and thought "Crikey, I need to bring that down!!"
All is well though..
But also issues.
First things first. Strings off. I noticed a bit of creaking in the top and stuck my fingers in the sound hole. One of the cross braces has split. Poor photo:
I reckon I should be able to get in to get some titebond along it then clamp it. Going to try tomorrow in better light tho.
Now, tuners:
Clip is 12mm inside width, peg is 6mm diameter. Photos:
Its a lovely size, well made, plays beautifully and sounds really really nice. Nicer than it has any right to..
Lots of swearing and glue infested fingers later....
It's recovering in ICU...
We shall see if it holds... was a tricky bit of keyhole surgery...!
Next, time to start scouring the internetz for replacement pegs..
Brace has stuck. I've reattached the tuning pegs for now and will restring tomorrow once the glue has dried properly. Will bring up the string tension slowly and check everything is ok, and then it's time to remind myself of how it sounds...
I'll get it up to a tone or two below the usual, and let it stabilise a bit more.
Will post some pics later on with it's new strings on. I've even given it a polish and a clean. Have I redeemed myself now @richardhomer ?
I'm going to keep an eye out for some new tuner pegs as well - I think stewmac have a set which will do the job.
I've strung it up. Got brave and put 13's on. Currently tuned a tone down to let things settle in. I'm actually quite amazed.
Relief was .010 straight off the bat. No adjustment needed.
Action is 2.5mm low E and 1.6mm top E. No adjustment needed.
No buzz anywhere - it's bright, articulate and has just snapped into life.
The peg on the G string is a bit loose - it will come off eventually, so a replacement set will need to be ordered. For now, they are serviceable.
I should have done this a long time ago. It's in the rack and back into playing rotation. I'm a bit sick really. My Gibson Songwriter Deluxe has more projection, but this is easier to play, and sounds more subtle and rounded.
Thanks to @ICBM for chiming in and telling me to grow a set, man up and put strings on it.
Something I didn't quite notice before… it has a "3 piece" back on the outside, but a "2-piece" on the inside. Doh! You'd think that if they were going to fit an ornamental joint strip, they would have at least tried to get the illusion right .
