Hi,i have no idea where to start with this,but here goes.
I have been playing Guitar(gigging),since the late '50's & in all that time i have never been able to get to grips with using or setting effects.
Over the years i have bought a few echo/reverb units & have always switched off or unplugged them after a couple of songs(or less).
I have in recent years even bought a couple of multi effects units GT100 & POD500HD(actually i've bought them twice)& still failed miserably with them.
I think the problem stems from playing just rhythm for the 1st 10 years of my playing,so when i switch on any effect,in my head it just sounds like i'm swamping my guitar sound,but i hear lots of players use them live & they sound great,for instance we regulary go to watch a young band who have no on stage amps whatsoever,just processors of some sort( i've also tried to do with the Multi Effects units),but their Guitar sounds are sometimes brilliant,for instance the sound on Queens(want to break free)is as near to Brian May as i have ever heard,so it is possible
I suspect the main problem is i have no idea what i'm doing setting the parameters or which effects are being used to create any given sound,maybe i should buy a better quality unit(Helix?) & give it one final try before i die.
But where/how do i learn how to build/program a required sound,ala Brian May(without aiming too high
![=) =)](/plugins/EmojiExtender/emoji/fb/smiley.png)
I think i'm beyond help,but if anyone could,point me in the right direction with how get to grips with any of this,i'd owe you at least 1 pint,maybe even 2.
Helix
Helux LT
AX8
FX8
whilst pricey, are much more user freindly than units of yore, It's fairly easy to imagine a virtual 'pedalboard' and tweak it as such.
Setting up a basic tone, and adding fx as needed is key in my opinion, trying to adjust and edit presets is on a hiding to nothing as they mostly have been designed to impress in a music shop.
I'd suggest doing some research on what Brian Mays set up is, then pop down to a shop that sells Line6 Helix and ask to have a demo, ask the sales guy to make a new patch with
Driven Vox AC30
Treble Boost
Harmoniser
Delay
and see how close you can get.
Thanks for the suggestion.
As someone that has gigged for many decades I can tell you that Joe Punter has little clue what he's lstening to. Having a small number of pre set effects and adding them as and when needed will give the illusion of a very expensive and extensive set up. Consider some basic boss pedals because they just work. You would be hard pressed to hear a difference to some esoteric boutique branded effects in a typical live gig setting. A good 'pedal platform' amp can make a lot of difference.
If you want that May sound, then the Carl martin quattro has all the things you need and sound stunning.
I'd TOTALLY avoid the modelling suggestions above- if you've struggled with aGT100 then the Quattro will be perfect.
They are stunning, but get the Mk2 with Chorus.
The only echo sound i really understand is the Rock & Roll slapback,which as far as i can tell is a very fast repeat of the original note,i think i'm struggling at a basic level of knowledge way below normal,especially for someone with my gigging experience.
I just have no clue about the basic parameters of even simple delays/reverb/chorus & when i try to get to grips with them,it just makes my sound worse.
Is there an idiots guide on effects & there use i could read,or am i lost
I'll probably get blasted by their haters but...
Have you tried watching 'that pedal show' on youtube? they go through the basics of a lot of things on there
Thanks for the link Sporky,i'll check that out too.
like a Zoom), read the manual and then play around with the effects. I'm not saying they will sound great but they shouldn't sound awful and you will get some sense of how things work. So, delay for example has three basic parameters and you can mess around with what happens when you adjust each up and down and then what happens if you do other stuff like add modulation. If you want to spend more money then you will have a better idea of the sounds you like and how to adjust them.
If you are chasing a very specific sound there's often a chance someone else has worked on it so google can be your friend there. As it happens the solo on the original of I Want to Break Free not played by Brian or on guitar at all, it's a synth imitating a guitar so even Brian has issues with that one and on the live versions I've listened to he doesn't sound much like the record (I think he just uses a wah).
What amp are you using?
Google is probably your friend on this regard. As @Sporky said though, nowt wrong with a guitar into an amp.
