Thanks dunstanmus. I don't want to go down the switching route like the gigrig stuff does. Too expensive and is overkill for my set up etc. However, when the 2 strymons are connected via their MIDI outputs/inputs can you save a Timeline preset or visa versa with whatever is selected at the time of saving. For example if I selected a tremolo with a certain delay sound on the Timeline and saved to a preset either on the Timeline or the Mobius this sound will broth be called up when I press the footswitch on that bank/A or B etc? Phew! I hope thats clear?
You could probably pick up some form of little midi controller cheap. Yes it's more gear but if you can't do what you want to do with what you have then you need more gear. In fact, what am I saying? Even if you can do it you still need more gear!! ;-)
