Both my Tele and strat style have my own 3 a side angled headstock
I'm not sure if anything is already pre made like that ready to buy
What about a Lp junior style neck if the fretboard will fit
Good luck anyway
(formerly customkits)
you do get snake head tele necks - but you will never fit the gibson tuners on one of those
Instagram
@wezv yes the paddle type one is what I was thinking would have to do the job, I was hoping to do something like what you did on my Airline but with the holes placed to fit the GForce tuner template. Is it a case of tracing the holes on to drill them, then drawing the shape of the headstock on, roughly cutting just a bit bigger then sanding off up to the drawn lines?
Instagram
For the holes, yes that would be the worry that there's no room for error, I presume I'd have to print the template off, trace to tracing paper, then that would trace onto the wood if I did the "shading on the other side of the paper over the lines bit". Actually, that does sound like something I could quite majorly cock up haha
I was going to say perhaps gsp basses might make you such a neck if you ask him
I really like the Japanse saw rasps, they are flat and have fine and course sides
Theyre great for doing necks
