Wudtone finish
  • underdogunderdog Frets: 8334
    daveyh said:
    I had the advice from Wudtone to mix the colour with the clear topcoat so the black sits on top of the wood, making it more opaque.
    Darkened it a little, but still nowhere near the translucent black I was after. Wudtone's repeated 'I think it looks awesome' really didn't help.
    https://imgur.com/gallery/hdPjv
    It's a cool finish if that's your thing but it's not black, I think you have a point being unhappy if black is what you wanted
    Never bought in to the wudtone kits, party because Andy was instantly dislikeable and partly because they seemed to be a hard way to get a below average finish.
  • It's a bit late now, but for deep blacks ink works well.
  • daveyh said:
    I'm definitely thinking it looks good, just not what I was after! I want to exhaust the possibilities of blackening it more first
    Ask Andy to send you another bottle, which I'm sure he'll do, and then use the dappling/dabbing technique. It will go on thicker and more solid that way, but the downside is that you will not have a flat finish, but rather an orange peel type effect. If you can live with that then give it a try.
  • daveyhdaveyh Frets: 691
    edited September 2017
    I did speak to him about it, bought a new bottle of the black colour to add to the clear topcoat. Made hardly any difference.
    My issues with the black notwithstanding, that amber looks amazing
  • John_AJohn_A Frets: 3775
    Here's the finished guitar
  • victorludorumvictorludorum Frets: 1069
    You must dab it very thickly. Rubbing it in doesn't work for solid colours. You will get a more solid finish by slapping it on, but the downside is the orange peel effect. I don't like the look of it, but you might.
  • @Jez6345789 Where do you get your Osmo from?
  • RolandRoland Frets: 8848
    Screwfix
    I get mine from Wood Finishes Direct.  They sell the small 125ml tins (Screwfix min is 750ml) which is plenty for a guitar or bass and is cheap enough to try two or three of the wide range of finishes to get the one that's just right for you.
