Listen to this prophet, '80% of the sound of a guitar is down to the tone-wood, but it can't be explained as its a spiritual thing'.
It's like The Enlightenment never happened!
getting a bit cold in the evenings - had to put the fire on for a bit tonight.
I love nothing more that a 'real' fire when it starts getting colder.
Mind you, times are hard here ooop North - I've only got my ash bodied Strat to burn. Still, I'm planning to replace it with a plywood Squier anyway - so I suppose I may as well put it to good use....
I tried a real wood fire but it took too much time sifting through the wood pile trying to decide which type of wood would have the best scientifically proven make up to burn most efficiently.
Thought fuck it and switched to gas. Now I can spend more time heating the house rather than wasting my time choosing wood.
We need the Chewbacca defence to win this
Look at the monkey
http://www.rabswoodguitars.co.uk/
https://www.facebook.com/RabsWoodGuitars/
My Youtube page
I need to do more research into this - I don't think subjectively feeling too hot or too cold is going to be enough to satisfy me - this needs some science....
My Youtube page
It'a all the same stuff made in the same place, but modern manufacturing facilities let them make subtle changes depending on which supplier you get it from.
The boutique gas days are dead.
You are better off getting solid state gas.
Dude.. its like spiritual man.... you just have to feel it..
Plus.. don't all guitarists know hide glue is always just better.. Its a fact... Gibson says so.
My Youtube page
'Solid state' gas sounds distinctly non-gaseous to me. I'm not convinced you know what you're talking about. I need to find a scientific research paper that will tell me what to think....
Well, that's your loss...
...I'm off to restring my coalcaster.
Sure, it is less resonant than a hollow body or acoustic guitar but a solid body electric guitar still vibrates and will do so with greater amplitude at certain frequencies.
This may affect the 'tone of the guitar
It all make so much sense... Just like this.. Its on the internet, it must be true..
Just like the TRUTH behind Stonehenge
My Youtube page
Instead we are expected to believe that such an explanation is beyond the realms of science, is something 'spiritual', or can only be understood if you tap and sniff raw wood, and that academic papers on the web undermining the myth of 'tone wood' (and I guess the people who wrote them, the universities they work in and so on) are all an elaborate fabrication.
On the other hand there is a whole raft of evidence showing why tone wood does not have an perceptible effect, ranging from the simple physics of a guitar body as a forced vibration system, through to the fact the 'tone wood' cannot be reliably identified even in acoustic instruments where any effect can be expected to be some magnitudes larger, through to rigorous experimental studies that have showed no 'tone wood' effect exists.
Sure, a guitar might vibrate slightly as a result of absorbing energy from the strings, but it is a massive leap to assume that this loss of energy in turn causes a consistent, perceptible change in the harmonics sounding on the string as sensed by the pickups, let alone that such a change is wood species dependent!
I have 'made up' nothing I have written here, simply drawing on the research of others, and it does amaze me that, despite all the debate, so few seem to actually want to understand better whether or not 'tone wood' does have an effect, exactly how it works if it does, and exactly why it does not work if it doesn't.
