IC beat me to it! Blackstars also have decently low FX send impedances so if needed an iso transformer can be used. You can get a twin channel iso-traff from Amazon for about a fiver but despite the very low cost they are really quite good. Deffo good enough for rock and roll!
BTW, if you can keep all the mains plugs on one strip.
Dave.
https://www.amazon.co.uk/AV-Link-Ground-Loop-Isolator/dp/B000NVWB9O/ref=sr_1_5?ie=UTF8&qid=1509875719&sr=8-5&keywords=ground+loop
That ^ is the one I meant. With all these isolation transformers they are low Z OUTPUT isolators, not 10k-10k INput traffs . They will give very poor results in higher impedance circuits i.e. passive guitar.
Yes, lifting a SIGNAL earth can often fix a hum loop but it can also give rise to RF breakthrough, an RF 'keeper capacitor' in the shield path generally sorts that. ...Hum/ground loops are often a reet PITA to sort!
Dave.
