You would need some sort of pre amp alongside it.
Look at the Vox Amplug series.
Some years ago I built my son a pre amp for his Strat using the LM386 1W amp chip. Even though the input Z is far too low at about 10k it sounded quite good. P of P to fit a FET buffer anyway.
Dave.
If you have any kind of pedal NOT of the daft "True Bypass" sht, just buy a Behringer HA400.
Or! Should you want to record on the lappy, a Behrry UCA 202. (+pedal)
Dave.
