Even a cheap tie clip condenser in the sound hole puts 'air and dimension' into the sound but the main volume content comes from the pickup. If the player is sat still on a stool and in an acoustic setting then mostly Mic and a bit of PU is noticeably better.
It the band is just a rock outfit and the acoustic guitar is strumming away in the middle of the mix forget the mic and just use the PU.
I've just had an LR Baggs Anthem SL installed on my GS Mini, basically an internal mic combined with an Element under saddle pickup, only had a few plays with it so far but it does sound bloody lovely. The under saddle pickup is purely to pick up the lower end sounds, and the internal mic for everything else. I highly recommend.
Edit: Forgot to mention, the volume control goes inside the soundhole, so no big unit stuck on the side.
My band - Crimson on Silver For sale - Blackstar HT-5S
Gear - Guitars, amps, effects and shizz. Edited for Phil_aka_Pip, who is allergic to big long lists.
As @Lewy said above, the K&K Pure Mini is the best I've come across for getting closest to natural sounds without spending mucho money for a blender system.
I've just installed a Fishman Neo D Humbucker which is very nice, I prefer it to the Fishman UST that I have in the same guitar. It's a nice sound but like most mag's, not particularly acoustic sounding, but the more body and air you have in your sound the less it will cut and the more it will feed back anyway. IMO for a completely true acoustic sound you really need to cover three things:-
String sound - Magnetic soundhole pickups
Body Sound - Bound Board Transducer - K&K pure or a mag with body sensing like the M1
Air - Mics, external or internal like the Lyric or Anthem
I've recently been experimenting with the mag into my mixer (Allen and Heath with Hi Z input), mixing in the UST and also an external Rode M3 for the 'Air'. As soon as I add the Mic positioning and EQ tweaking comes into play and since the mag is a very nice (if not accurate acoustic sound), I find it easier to just take the mic out of the equation. I'm tempted to add a K&K at some time to give me more 'body', they are pretty cheap and may mix well with a magnetic.
I might get an SE Electronics mic or something.
Don't give up on the Dean Markley, most mags have good feedback rejection and solid bass, useful attributes that can be added to other pickups to get a better overall sound. Also handy if the K&K was struggling with feedback in a loud situation, at least you could dial it out and have a usable sound. And in a quieter situation you could go more or all K&K for more acoustic realism.
Wired like this the output would be stereo, you would need a y lead to split the sources and then mix through a desk, amp or PA.
The wiring is simple as well because it is passive so you don't have to add a battery compartment. I've plugged mine straight into a PA with a bog standard active DI box, and its got enough oomph so it simplifies things a lot not having to worry about changing batteries.
Yes and the good thing about the k&k, unlike a passive UST is the output is plenty to go straight into an amp. So I hear.
