https://www.ebay.co.uk/itm/New-6-35mm-Mono-Male-Jack-to-2-Dual-RCA-Phono-Female-Headphone-Splitter-Adapter-/152259953633
Hi-fi it is not... but if you keep the gain low it's tolerable for listening to in the same way as an old AM radio
Soldering the two wires together will also work if you want to do it yourself.
Otherwise there is a risk - small, but present - of each output trying to drive the other. In poorly designed electronics (ie most of it) this can result in damage to the output stage.
Shorting L&R line outs together should not cause any serious problems with anything remotely modern. A headphone amp should be especially s/c proof since 8 Ohm phones DO exist! There is also every chance of a tangled cans cable being damaged and shorting. In short (HA!) if it can't stand a short it must be 'reet ***T!"
There is one special case however. If you have a 'proper' balanced line output and un balance it by shorting one leg to ground the unfortunate IC section will generate horrendous distortion and this can crosstalk into a wanted channel.
Dave.
Properly designed it'd have series resistance as Danny points out the iDevices do, but there's a lot of crap out there.
Agreed but a headphone amp is not a VERY low source resistance power amp. Any 1/2 sensible design will have a series resistance (to somewhat equalize drive for the variety of H/P Zs if nothing else) and therefore a total short is not possible. I.e. the amp should be continuously rated into it own load.
If you DO have a shit H/P amp that self destructs, bin it and buy better. My 20 quid Berry HA 400 is bomb proof.
Dave.
But for the sake of three resistors and a bit of heatshrink...
