Solutions for a slippy cab
BowksBowks Frets: 436
Having just picked up a new Harley Benton 2x12 and a lovely Marshall 30th Anniversary head, I have discovered the head is sat atop quite a slippery tolex surface, which worries me a little!
What have others used in the past to resolve this? Gaffer, or is there another solution you'd recommend?
  • ecc83ecc83 Frets: 1664
    Paint the feet of the head with Copydex. Might need a few applications and it takes hours to dry this weather!
    Or! At our local RockBottom shop they sell "rubbery" mats of an open mesh design and they are VERY non-slip. My poorly wife uses a bit of one to grip bottle tops. Very cheap and you can cut several pieces to lay on the cab. Keep spares in gig bag/gitcase.
    Dave.
  • ICBMICBM Frets: 73031
    Put standard rubber feet on the amp instead of those daft hard plastic ones. They break easily if you catch them on something while you're carrying the amp and the foam pads inside them are virtually worthless as 'shock absorbers' anyway.
  • drwiddlydrwiddly Frets: 918
  • BowksBowks Frets: 436
    Cheers all. I have ordered some of the grippy mesh. Looks quite handy as a work surface too, so ordered enough to roll out under a guitar too.
