Not being snarky, am genuinely curious if anyone has any thoughts.
Bandcamp
Spotify, Apple et al
Bandcamp
TFB newbie here.
Interestingly, because the impedance of speakers vary with frequency, and the resonant nodes of the cone are reflected in this too, two different model speakers connected in series can sound quite different to two of the same speakers connected in parallel. This is due to the two different impedance curves subtracting or adding when the speakers are in series. Thus creating an entirely new impedance curve, therefore tonal response.
Also relative: Speakers, when driven from a high output impedance such as a valve output transformer or transistor power amp with modern 'constant current drive', will actually enable the addition of harmonics added to the tone that are the result of the cone's instability from being 'under-damped'. The mentioned newly created series speaker impedance curve 'tone' (I prefer the term sound, as new harmonics are created) is greatly influenced by this too. Due to the cone under damping, you hear many harmonics in the sound that are NOT created by the amplifier itself. Behaviour rather like a car wheel with knackered shock absorbers. Very rock 'n' roll!
"Just because it's never been done before, is the very reason to make it happen" - Me!
