Two Thin line TC's Swamp ash body with flame maple cap's, both the bodies are fully chambered. They have no binding on them but can be fitted if required. Also, the F hole has not been machined, again can be if required.
TC on the right weight 2lb 12 oz's.
The neck is Maple with a rosewood finger board.
Nut 43.2mm
21 frets
21.5mm at the 1st fret.
23.3mm at the 12th fret.
SM #149 frets, .103 x .046
MOP inlays
SOLD
TC on the left weight 2lb 13oz's
The neck is Maple with a Rosewood finger board
Nut 43.1 mm
21 frets
22mm at the 1st fret
24mm at the 12th fret
SM #154 fret's .100 x .050
white dots
SOLD
£245 each inc P&P
4 necks for sale
From left to right
Strat neck
Maple / Rosewood
21 frets
Nut 43mm
1st fret 21.7mm
12th fret 23.5mm
SM #149 .103 x .046
MOP dots
£140 inc P&P
T/C neck
Roasted maple
Nut 43mm
22 frets
1st 23.5mm
12th fret 25.4mm
JD 6100 frets .110 x .055
MOP dots
SOLD
£160 inc P&P
T/C neck
Flame Maple
22 Frets
Nut 42.3mm
1 st fret 20.3mm
12th fret 22.4mm
SM #154 frets .100 x .050
Abalone dots
£150 inc P&P
SOLD
Strat neck
Maple / Rosewood
Nut 43mm
21 Frets
1st 22mm
12th 23.5mm
SM #154 .100 x .050
White dots
£140 inc P&P
P-Bass Lightweight Swamp ash body with a Maple / Rosewood neck.
Nut 43mm
20 frets
1st fret 23mm
12th fret 25mm
MOP dots
£220 inc P&P
Strat body light Alder with a Maple / Rosewood neck
Neck
Nut 43mm
21 frets
1st 21.3mm
12th 22.8mm
SM #149 Frets .103 x .046
MOP dots
The headstock on the strat neck can either be left as is, or it can be shaped to small headstock or a large headstock at no extra cost.
£220 inc P&P
All the necks are Fender scale with 9.5" rad finger boards.
SM = StewMac
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
All the necks have a 9.5" rad.
