Plywood Guitars
Simon_MSimon_M Frets: 542
Perhaps not the most exciting subject...
I've heard a few people joke about plywood guitars but I don't think I've ever come across one. Perhaps I've never looked in the right places.
Are they still around?  Did Epiphone or Squier ever put out plywood guitars? Or is it one of those things that was solely the cheapest of cheap Chinese?
Also interested if they were made from multiple sheets laminated to each other i.e. true plywood, or more like a catchall term for a body made from multiple pieces of cheap wood and glued any old how?
And of course, lastly, did they sound truly terrible?
«134
  • richardhomerrichardhomer Frets: 24865
    My first electric was a CSL copy of a (Keef-style) Telecaster Custom with a ply body.
    Once I fitted it with decent pick-ups it sounded pretty good....
  • ICBMICBM Frets: 73019
    There are loads of them, from the 1960s up to at least the 1990s, although they don’t seem as common now. Both Squier and Epiphone had some models, as well as many more highly-regarded brands.
    Almost all the ones I can think of are true ply, with alternating grain direction. And no, they usually don’t sound bad - it’s not easy to tell the difference normally. Plywood guitars tend to sound bad because they were made to be cheap and are fitted with cheap hardware and electrics, not because they’re ply.
    One of the exceptions are USA Standard Fenders from roughly 1993-2000, which are closer to a description of ‘blockboard’ - ie multiple roughly square-section blocks with veneers front and back. Some Mexican Fenders were also like this.
  • Simon_MSimon_M Frets: 542
    Truly fascinating answer, thanks! I kind of can't believe that a USA standard Fender was built like my chopping board. I've always assumed they were 3 pieces of wood maximum.
    That supports ICBM's post that the main problem with them is the hardware. I'm quite keen to try to find one and see what it sounds like.
    There is a theory that the neck contributes more to tone than the body - which if true goes some way to explaining this. The neck on that guitar was solid wood....
  • LuttiSLuttiS Frets: 2246
    Didn't some manufacturers make chipboard guitars too? Sure I heard that somewhere...
  • FunkfingersFunkfingers Frets: 14736
    In a recent trawl of eBay for instruments in spares/repair/project condition, I found an Aria The Cat going for peanuts. It took a moment to remember why that model was so affordable. Its body is ply.
    Ply is not necessarily a bad thing. Some cracking slide guitar tones can be extracted from dirt cheap guitars.
  • baldybaldy Frets: 195
    I have a Hohner Rockwood LX250G LP copy which is plywood.
    I think that it is a fantastic guitar & I prefer the feel & sound of it to a couple of £400-£500 Epiphone LP"s I have tried even as stock.
    Image result for rockwood by hohner lx250g image
    Looks identical to this one.
  • WhitecatWhitecat Frets: 5506
    Danelectros are made from Masonite...
    edited July 2018
    I think I can remember some 1960s cheapos that might have been, but I'm not certain - possibly some of the vinyl-covered German solids. The 90s Ibanez Talman was made from MDF (or probably more correctly HDF)... and the 80s Gibson Sonex something similar, called "Resonwood" - I'm not certain what its exact composition was, but it appears to be more resin than wood.
    Whether it has any real effect on the 'quality' of the tone is difficult to say - as with the ply guitars, it's just one of a number of factors. They don't sound exactly *like* all-wood guitars, but the Talman in particular has quite a lot of fans, including some pro endorsements. Both the Talman and the Sonex are quite heavy though.
  • Pete24vPete24v Frets: 235
    My first guitar, a 1991 Korean Squier was plywood, which split apart 2 years ago. So I replaced the body with a 2 piece alder thing from ebay.. Still sounds like the same old guitar.
  • valevale Frets: 1052
    edited July 2018
    i've got one of these old kays years i bought years ago (when they were not the stupid money they are now). 'totally plywood!' as nathan barley would say. pocket money thrills in the old school style.
    even the neck appears to be made of finely laminated strips, all bound together with a super-resonant glassy varnish. some are horrible, but some are fun players. i like mine anyway.
    this one sounds good enough.
    hofner hussie & hayman harpie. what she said...
  • JezWyndJezWynd Frets: 6170
    edited July 2018
    I picked up a Fender Bullet recently. It's from 1981 I believe. They took the plywood aesthetic and ran with it - pickguard doubles as bridge and string retainer. Sounds fine and plays well thanks to a very nice neck.
    Famously, the advertisement for the original Yamaha Pacifica 112 illustrated its naked, natural finish, solid wood body next to a Korean Squier whose thick paint had been abraded away around the edge of the lower bout to reveal laminate.
    Much depends upon how snotty you want to be about laminates. The Gibson ES-335/345/355 body is steamed and shaped from laminated tone woods.
  • dindudedindude Frets: 8573
    Yamaha changed the landscape somewhat when they brought out the Pacifica 112 in early 1990’s with natural finish showing solid wood.
  • martmart Frets: 5205
    Aren’t 335s made of plywood? ;)
    I nearly forgot this... probably the most plywood of all plywood guitars!
    https://i.pinimg.com/originals/75/3a/2a/753a2aa33bfb44a5df480266836b3ac7.jpg
    :D
    (If you don't already know, it's a Gibson Zoot Suit.)
    1reaction image LOL 2reaction image Wow! 1reaction image Wisdom
    edited July 2018
    i had a 1970s Aria bass with the classic 'made in japan' plate (probably budget motsumoko) and that was exactly the 'chopping board' blocky type body @ICBM was describing.
    the paint came away like egg shell from around the horns and bottom pin and it was clearly not laminate but block.
  • StuckfastStuckfast Frets: 2432
    My first electric was a Westone Thunder II. It was made of MDF.
    I also have a Japanese Strat copy that is plywood. Probably the more confidence-inspiring of the two.
