I'm looking for a clean boost for a specific purpose:
The mag pickup in my fretless is now pretty much balanced output wise with the piezo - the pickup is hidden under the fretboard and so a little way beneath the height you would normally set it under the strings. Through the new preamp onboard it's perfect - gives a nice midrange blend with the piezo (which is what it's meant for)
However, this new preamp has a push pull volume pot with passive/active
The sound in passive mode is def. different and, well, usable in a good way. It's really rather quiet tho..
So, I'd like a small clean boost that won't colour the sound and has a super low SNR so it won't add too much gain hiss.
Thoughts?
No noise, just a huge boost to your signal when you need it. Looks the business too!
Facebook: @northernstomps // Instagram: @northernstomps // Twitter: @northernstomps
Specialist Retailer Of Handmade British Stompboxes // https://www.northernstomps.com/
Currently Stocking: Hudson Electronic/Raygun FX/Zander Circuitry/ThorpyFX/Rainger FX/Life is Unfair/ Magnetic Effects/Fredric Effects
