In which case, use gently heated high-strength Araldite instead of superglue.
Failing that the pickup should be sent to us to have a new Baseplate fitted. Unfortunately that requires the lower coil to be replaced.
Lest option, we send you a new Baseplate which you fit over the existing one. The screws currently must be poking out the bottom of the existing baseplate by 2mm for this to work".
