Benefits for recording
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
For me changing over to modelling was a two step process, and took about six months. First amp modelling, but playing through the power stage of my amp. Secondly switching to FRFR, and getting rid of the amp altogether. A powered floor monitor takes up less room than an amp and speaker. At the end of the evening I don’t have to wait for the valve to cool down before moving my amp.
There is a different sound with modelling. You hear what the audience does, like an amp mic’d up through the PA. It comes through your monitors, not from an amp behind you. So I can have whatever monitor volume I want without affecting the FOH. It has also stopped arguments about volume. I know exactly what settings I’m using, and that they haven’t changed.
Benefits:
- Flexibility. You can have several different amp sounds without a multi-channel amp.
- Space.
- Convenience.
- Volume. You control it.
Cons:
- You have to learn to use it. With a valve amp many decisions are made for you, and you can’t change them without buying a new amp. With modelling you become much more aware of compression, EQ, and the way they appear to change with volume.
- Getting used to hearing a recorded or mic’d up sound.
I love the sound of the amp but I hated carrying something so heavy, took up a lot of room and never got to use it with the volume passed 1.
Bought the Helix, used the PV power amp to get a tone. Loved it.
Then sold the PV and bought a powered speaker.
Loving it and it's about a 1/4 of the size and weight.
Currently using an AMP1, 4-cable method and an HX FX - on the same smallish T-Rex pedalboard I used to use for my conventional setup. In the main, I'm using the clean channel of the AMP1 and taking the "pedal platform' approach, but the other channels and features on the AMP1 get used too. I'm controlling it from the HX FX via MIDI.
The AMP1 doesn't need a speaker load, so you can plug into the PA and use a speaker IR if you want to. I've got a BluBox for that, but the HX FX will load an IR, too. I'm using a 1x12 cab.
I should qualify this by saying I've never used anything from Fractal, nor a Kemper, nor a full-fat Helix - so I'm not dissing any of those solutions cos I haven't tried them. But there are alternatives that seem to be working for me so far....
For guitar I'm 100% Helix
For bass - a bit of both. 100% Helix in the house / recording, but for my current gig I take a Darkglass M900 and a super lightweight Barefaced One10 cab - sometimes a pair. It's a swing band so I don't need all the options the Helix gives me - although if they had a PA worth having then I'd just take the Helix and go direct and leave the amp and cab at home.
The fact that one of the best players on the forum from what I've heard, is so far out of touch with how good modellers now are probably indicates the rest of us spend too much time looking at new gear and not enough time playing
I've not gigged it yet, but am absolutely happy with it for recording. I think it sounds great, and because of my previous experience of the real amps, pedals, cabs and mics being modelled I wasn't swamped in the possibilities it offers - just got straight to work with it.
Bandcamp
Spotify, Apple et al
My keyboard rig in that band is 100% modelled too .... just a dumb midi keyboard controlled Xpand software on a Macbook
For pub covers gigs I'm still HRD and pedals, for corp gigs Marshall rack system and 4 x 12" (shock & awe approach )
For live stuff, I've mucked around all over the place - used loads of different modellers, modellers with pedals, valve amps with pedals etc - and I'm settled on Helix LT -> SD Powerstage 170 -> guitar cab. I honestly couldn't be any happier with my tone than I am right now, particularly since I've tried other options since getting the Helix and it still gives me the best setup.
Here's the thing...a lot of folk say that using modellers involves a tonal compromise, regardless of whether you intend it as such or not. However, using valve amps in a practical rig also involves compromise - at least, it always has for me. There isn't a valve amp in existence that gives me the exact combination of clean, crunch and lead that I want - much less one which gives me each of those gain levels at varying volumes. So...I then ended up with various boost and EQ pedals to mould it into kinda what I wanted.
Those options are baked-in with a modeller and are trivial to implement without loads of moving parts. They're extra-easy with the Helix thanks to snapshots. The result is that I can make exactly the tone I imagine in my head and keep it consistent across gain and volume levels.
Plus...there's the fact that I'm a broken shell of a man, and my entire rig (Helix, amp, cab, guitar and cables) comes to about 22-24kg depending on the guitar I take. That's an easy lug from the car in one trip or an even easier one in two, and I can't overstate the importance of that.
I genuinely do believe that, for me, my current rig is the best of all worlds. Sure, it'd be nice to have a sprung switchless option on the expression pedal without resorting to an external unit, and even nicer to have really accurate fast-tracking polyphonic pitch shifting, but honestly? They're nice-to-haves in comparison with the rest of it.
..it's something I really need to look at especially for portability ..I feel as though I am miles behind with all the new technology
Other factor no-one has mentioned is reliability.
I've had my Kemper a while now, and I'd estimate that I've put over 1000 hours of use on it. I've not had a single issue in that time.
I don't think I've ever got 1000 hours (or anything close to it) from a valve amp without something needing doing - even if it's just valves that go bad and need replacing. Replacing valves isn't the end of the world, but it is a hassle, and they have a habit of starting to make sputtering noises at the most inopportune times! If it's the power valves then I've got to open up the chassis to bias it as well.
If you are going to use a modeller live, you do need to make sure that you have decent monitoring. I tried using mine live 4 or 5 years ago but gave up because I didn't have decent monitoring available, and couldn't really hear myself on stage. I've now bought a QSC active cab, which has solved that problem.
I can fix anything on a valve amp myself, but my last two modellers are landfill already. I have spare valve amps lying around if one dies (it's happened twice to me since 1980), but I'm buggered if I'm buying two Kempers just in case.
I started on modellers, my first amp only had a clean channel so I used to plug my V-Amp 2 into that. Always liked the versatility even if it wasn't the best sounding modeller by current standards.
So much easier to port around, incredibly versatile with tones and sounds, pedals etc. Superb pieces of kit - IMO, from all of them I've tried, the Kemper just nails the 'feel' of playing a valve amp as well.
You might be able to fix everything on a valve amp, but if a valve starts to make spluttering noises mid-gig because of a bad valve, being able to fix it doesn't stop massive problems with your gig. That kind of thing is far less likely to happen with something like a Kemper.
