Quick question about Fender Highway One's...
... were they all made in the USA or are there Mexican versions?
  • Philly_QPhilly_Q Frets: 23583
    I'm pretty sure they all say made in the USA.  But the parts were made and finished in Mexico and assembled in the US, so it's a fine line.
    I think that's right.  No doubt I'll be shot down in flames if it isn't.
    Cheers Philly, I've just dug up a thread on the Fender forum which suggest the hardware is MIM but body and neck are USA. That's good enough for me: )
    Thanks again
  • guitars4youguitars4you Frets: 14750
    that is how I read it as well
  • duotoneduotone Frets: 1024
    Remember drooling over these in Soho Soundhouse back in the day.
    Did they have satin finish necks?
    They did.  Satin urethane neck finish, thin satin nitro body finish (again if I remember correctly).
    And big headstocks too.
    If only they'd had fat necks I'd have bought 10 of 'em.
  • AlnicoAlnico Frets: 4616
    edited February 2019
    They came with a full size, USA Tremolo unit with 56mm screw spacing.
    It was the same 6 point unit that they fitted to the AVRI.
  • JD50JD50 Frets: 662
    There were 2 types of highway 1?
  • newi123newi123 Frets: 912
    Yes, the early ones (like mine) had small headstock and thinskin finish, but they are not nitro. The neck isn't satin finished either.
    The later big headstock ones are nitro finished.
    Mines been my main gigging guitar for 17 yrs now, with a set of Seymour Duncan's in it.
    If I remember one also had the grease bucket and the other not?
    I think they changed the bridges too, the early ones had the vintage 56mm spacing, the later ones had narrower (52.5mm?) saddle spacing but still with vintage mounting-screw spacing.
  • John_PJohn_P Frets: 2756
    I have one of the early ones.    Small head, vintage trem.    I replaced the pickups with fender noiseless.    I thought the early ones were nitro as well though - sure that was one of the reasons I bought it, but either way it’s a cool guitar.
    I thought they were too, which is also one of the reasons I bought mine. Took it to a very well respected guitar tech for the pickup swap and he insisted it wasn't....... went back and checked the reviews and blurb and the originals were always referred to as thinskin rather than nitro.
    Either way, it sounds and plays great!
    I just picked up a small headed HW1 which was advertised as being a Mexican Highway One which was the reason why I posted the original question.
    I'm surprised it isn't nitro (but really doesn't make any difference to me) as it has worn quite well and the neck has subtly checked.
    So was/is it a polyurethane finish?
  • gavin_axecastergavin_axecaster Frets: 527
    I think all are nitro over poly undercoat, both pre and post "Ugrade" in 2005/6. When the American Special was introduced a few years ago it was basically a H1 with poly finish.
  • SteveRobinsonSteveRobinson Frets: 7122
    I've refinished a few of the early ones. The nitrocellulose wipes off with thinners leaving a thick polyester base coat.
  • I've refinished a few of the early ones. The nitrocellulose wipes off with thinners leaving a thick polyester base coat.
    That sounds bang on for the body. The neck I would say is nitrocellulose, do you think there will be poly under that? Not that I'm going to touch any of it.
    I managed to secure a lefty in blond, rosewood board, with a big headstock. 99% perfect. PuPs were too brittle.
    They are a belter, easy to play and not so expensive you're worried about scuffing it.
    The finish was satin, you're right. So easy to play.
    If I had talent, I'd be talented.
    Injured Veteran and head injury survivor. Bouts of grumpy behavior and brutal humor are to be expected.
    Red meat and functional mushrooms.
    Persistent and inconsistent guitar player.
    A lefty, hence a fog of permanent frustration
    Not enough guitars, pedals, and cricket bats.
    USA Deluxe Strat - Martyn Booth Special - Epi LP Custom
    FX Plex - Cornell Romany
    I'm sure the neck is polyurethane, standard Fender USA.
