Which Tube Screamer do I need?
PhiltrePhiltre Frets: 4178
I need to get a Tube Screamer as a reference pedal to compare to clones and pedals that I build. What would be the best option? I need the classic TS sound (whatever that is) and to be cheap.
  • soma1975soma1975 Frets: 7008
    Ibanez TS Mini. It's like £55 and is spot on.
  • ICBMICBM Frets: 72981
    Ibanez TS-5.
    It's the exact same circuit as the TS-9 but sells for around £25-£30 on Ebay.
  • 57Deluxe57Deluxe Frets: 7350
    I have several mini types and is slight differences but I agree that the Ibanez TS Mini does sound rather good - better than the larger sibling even!
    <Vintage BOSS Upgrades>
  • PhiltrePhiltre Frets: 4178
    edited February 2019
    I have an Ibanez TS Mini arriving later today. It's my first Tube Screamer! (No longer a TS virgin?)
  • dindudedindude Frets: 8567
    Get a green one
  • £500?
    Accept a substitute and £487 beer money :)
  • colourofsoundcolourofsound Frets: 403
    If you can get a Mojo Hand Rook OD second hand (around £70-£90 usually) that would be ideal. I have one and its an excellent TS that will also give you clean boost, rawer asymmetic clipping and you can get rid of the mid hump if you wish.
    EDIT: I did not read your OP properly. TS Mini is the one to get, :D
    Thought I better re-post this. Thanks for advice, guys!
    Well done. It's all the tubescreamer anyone needs.
  • EDIT: I did not read your OP properly. TS Mini is the one to get, :D
    Ah. Me neither. As you were.
    You should still get the Berry though.  =)
    Update - I'd been using a Tone City Kaffir Lime as (what I thought was) a TS clone. There are videos comparing the Tone City with a TS which may lead you to think this.
    Actually the Tone City Kaffir Lime is not a TS clone, but rather a Xotic BB Preamp clone. Now I have a real TS I can compare. The TS has more mid-range than the Tone City. Similar, but different.
  • Hydra19Hydra19 Frets: 329
    I got a maxon od9 as my first tube screamer. It's good, I'm certainly satisfied and think it sounds better through my Fender boosting the clean sound rather than adding overdrive but I have a very good use for mine
