I should probably add that I'll be using it amplified mostly, playing TexMex/Country/Latin-style music mostly, eg. Mavericks, Steve Earle, etc.
Cheers,
R.
Eqd Speaker Cranker clone
Thanks,
R.
Not cheap though £20 odd a set. But interesting to try for a while.
Football is rubbish.
I had just installed expensive Daddario carbons on my guitar and was getting a bit obsessed with it. His approach is just to use standard Daddario strings at £8 a set and change them regularly (a week or 2 before a concert certainly). I guess his view was that new strings generally sound better, but the difference to tone given by the premium types is less important.
Since then I have done the same and used standard Pro Arte strings (albeit I prefer hard tension).
I would think if you are amplifying it would make even less difference as you have all the flexibility of EQ on top.
I've used D'addario nylon strings on and off and they are decent but I prefer Luthier strings and also a few La Bella sets. The 427 set might have my favourite trebles.
