Is the hand drill a better alternative or THE alternative?
It's replacing a licensed Bigsby with a USA model B6 so all the work is at the strap pin end.
Good advice on the dowel. Is it likely to be strong enough to re-drill into after?
And cutting off flush do you saw then sand?
Thanks
It's a neat little tool actually. Also glued the dowel in as @ICBM suggested very easy and got it flush without having to cut or saw.
