100 Watt doesn’t on the red channel, boost is nice on the blue channel. In this case I’d use the EP rather than the OD808 though, but Maxon would still sound good.
@Fortheloveofguitar how will I be able to tell the difference, mate? Obviously, short of playing it.
There’s not many second hand version 2 about though at the moment so you may have to settle for V1 at a good price but if you’re gigging with it then definitely hold out for a V2 to avoid the issues that Drew mentioned as they are a real pain in the backside
The 100w doesn’t have the problem as it has its own dedicated gain/volume/EQ
I picked up a 100w for only £500 and I was originally looking for a 50w but couldn’t find a V2 second hand so picked up a bargain
I WANT TO BUY:
Fairfield "The Accountant" Compressor Pedal.
I find that a TS will tighten it up but the amp them becomes brighter and loses a lot of its natural thump
Will it tighten it up though without losing too much of the amps character?
