Suggestions for a do-it-all guitar...
LordOxygenLordOxygen Frets: 319
edited May 2019 in Guitar
I have a milestone birthday later this year and I've got the green light to gift myself a special guitar to mark the occasion. I'd like to find a guitar that can give a wide range of tones capable of replacing both the Epi LP and the Mexican Strat that I have now.
I'm at a bit of a loss really where to start, never considered a highish end guitar before, or picked one up to play because I've never been in a position to buy one.
With a £2-3K budget. new or used from a dealer, what brands should at least be on my (hopefully long) shortlist to try as a do-it-all guitar?
An obvious one to look at is PRS, any others?
Thank you.
«134
  • King85King85 Frets: 631
    What style of guitar do you think you're after? Super strats can be found with hsh setup with coil splits to do a bit of everything.
  • LordOxygenLordOxygen Frets: 319
    edited May 2019
    I'm really trying to be as open minded as possible, I'd consider a single or double cut guitars, I know PRS do coil splits,
     I like the neck PU tones on my LP and Strat and the bridge on the LP.  I play at home for my own amusement and dabble with lots of styles (blues, rock, metal, jazz)
  • crunchmancrunchman Frets: 11517
    PRS DGT is very versatile.
    A good 335 can rock out, but also be very articulate to replace the Strat.
  • richardhomerrichardhomer Frets: 24865
    ‘Super Strat’ style guitars are a good option - but the HB sounds aren’t that close to a Les Paul - whether this matters is down to taste.
    A PRS DGT gets you very much into LP territory - but their are no ‘Inbetween’ single coil sounds. What single coil sounds there are, are good - but lack the ‘snap’ of a bolt-in maple neck guitar.
    There is an inherent level of compromise with all ‘do it all’ guitars. You need to compare a few at a good dealer and decide if any work for you.
  • stickyfiddlestickyfiddle Frets: 27701
    edited May 2019
    Honestly, I wouldn't worry too much about specs and trying to find one thing that does everything. I would go to a good shop with good stock in your price range (Peach, Coda, etc) explain your budget and aims and try everything that takes your fancy.
    Obvious to-try suggestions would be PRS DGT and ES-335 and maybe Collings if the budget will stretch a fraction (or go used). Or go towards a superstrat type which takes you to Suhr, Tom Anderson, etc
    But the key thing is to go and try stuff and find what works for you - the player is much more important than the guitar, so find something you click with and you'll be happy. For me, that would likely mean a Custom Shop SG or a CS-336, or a really nice Jazzmaster or Strat, but I'm not you.
  • NikcNikc Frets: 629
    Surly a PRS Paul's guitar would be a good place to look - the PUP's are a bit special and there is an SE model you could get yourself a stocking amp to go with it ;)
    Or get a tele of course
  • hubobuloushubobulous Frets: 2372
    A Suhr with HSH and coil tap gives you every tone you'd ever need
  • equalsqlequalsql Frets: 6237
    This.. A good Telecaster will cover pretty much all musical styles.
    2reaction image LOL 0reaction image Wow! 3reaction image Wisdom
  • RandallFlaggRandallFlagg Frets: 14007
  • FuengiFuengi Frets: 2850
    A semi hollow Telecaster with a coil split humbucker will cover a lot of ground.
    The nicest two guitars I have ever played are a Suhr Strat and @peteri 's Gibson ES 330. I'd have either in a heartbeat.
  • andy1839andy1839 Frets: 2212
    Patrick James Eggle 96.
    http://i67.tinypic.com/4sfcdd.jpg
  • meltedbuzzboxmeltedbuzzbox Frets: 10340
    Please listen to this man
  • slackerslacker Frets: 2275
    Often guitarists know what they want and don't have the money. So as you have the money, try a lot of guitars to see what you like. So as to not to end up try all the guitars made, try to eliminate things.
    Tremolo (vibrato) bridge? To bigsby or not to bigsby? Etc
    Pickup type, number, splits etc.
    Fingerboard, material, scale, radius
    Go to a well stocked shop on a weekday and try stuff.
    Happy hunting
  • chris78chris78 Frets: 9595
    A tele with a 4 switch. I can use it for pretty much any musical style.
    As above, you also owe it to yourself to check out an Eggle 96. The twin humbucker models have coil splits and are exceptionally versatile, the hss have stunning single coil tones in neck and middle and a great splittable humbucker at the bridge. They’re as well made as PRS too.
  • uberscottuberscott Frets: 130
    Suhr Alt-T Pro covers a hell of a lot of ground. Semi-hollow swamp ash body with bolt-on maple neck, and two humbuckers with split coil switching gives you a big ol' range of tones.
  • MikeBMikeB Frets: 178
    For that amount of cash a couple of nice second hand items would give you the best of both worlds?
  • TTBZTTBZ Frets: 2954
    edited May 2019
    Depends how much you like the in-between sounds but I'd probably just get a nice Les Paul with decent splittable pickups to get you close to that singlecoil neck tone. The new Les Paul Modern actually looks great. I liked the new all access neck join on the one I played. Very tempted to save up and find a nice one for myself, trade in my SG on one.
    I find splittable humbuckers more versatile than singlecoils - you can approximate the twang and hollowness with a split but can't really fatten up or "un-twang" a singlecoil without the use of pedals.
    You know that's literally what tone knobs are for, right?
    It still sounds like a singlecoil though, to me.
  • p90foolp90fool Frets: 31920
    There isn't a single guitar which will cover all bases as well as your current two budget guitars, at any price.
    Pickup style and placement and guitar construction have their tonal limitations, however much money you throw at them.
    If you simply MUST switch between a Strat and a Les Paul mid song then you'll need some kind of compromised do-it-all guitar, otherwise just stay where you are or upgrade what you have.
    If you really want to treat yourself for your birthday though, just buy a great Telecaster and you may end up not needing the other two anyway.
