Transmitter fits perfectly in one of these on my belt, with one of the belt pack adapters they sell poking through the hole in the bottom to plug my cable into: https://www.amazon.co.uk/gp/product/B0016KJKIG
Won't transmit aswell through walls (ie walking around house/ into different studio room) but that's no issue on stage .
Little sticky pad bot great. But I just use leccy tape to attach to guitar.
Crazy long battery life too.
Depends how much you gig and what sort of range etc you need (the G10 is not great but I do the same as you for listening to the sound out front). Smoothound has a lot of positive feedback on here tho - may try one next
Very happy with it, although be aware that the little screws can come undone if you jump about a lot like I do!
I tend not to use it now because the proliferation of wireless devices among band members, ironically, created so much extra need for wires (mainly power) that it was doing my nut in (being the one that does the majority of the set-up).
Batteries seem good and the indicator is right. I buy a dozen AAAs from the pound shop and keep spares on top of the amp just in case, it takes seconds to swap but the new batteries render the transmitters ON! So beware. Highly recommended.
Anybody else have this issue?
I've since replaced it with a boss WL-20 and it's much quieter, although I think the range was better with the smoothhound.
Collision rock band
Mine has done a few hundred gigs with no issues, but the crappy USB socket does look flimsy, so stopping drummers crunching across everything on the stage on the way to their kit is even more of a priority than usual.
I've looked at the Smoothhound too, but the two posts above are not the first reports I've heard about DC noise, plus I really can't be arsed with batteries.
I plug my G10 into its charging dock fifteen minutes before showtime and that gets it through three-hour gigs effortlessly.
Have heard good things about Smoothound though.
