Well I got home last night having been away for a few days, any my wife and son have decided to buy we a road bike. Nothing fancy (thy got it from decathlon), but has 24 gears, a carbon fibre fork. Now not planning any major upgrades (maybe the pedals and some clip in shoes).
Now I am an unfit bastard (but a confident cyclist). Plan is to get to the point where I can do the Go Ride London to Brighton run next may. So how do you guys suggest getting into the swing of things.
First hurdle is to get over a sore bum (and I do have a decent seat), then build up my fitness, now I live in SE London, so not exactly a nice place to ride with all the traffic.
Should I find some nice flat trails to start with, or best go for hilly rides and take them slowly until my fitness levels are up.
Do I get a Mamil outfit ;o)
its simple but not intuitive if you haven’t used road bike gears before
don’t use the gears at each extreme - use the middle gears . You will have 8 gears on one handle and 3 on the other. Stay around 3 to 6 on the (probably right hand), and use the 1 2 and 3 instead to give you a comfortable gear. Don’t use 1 and 8
with Decathlon bikes you are entitled to a free setup after a month. You will almost certainly need it because the gears will be “clicking” and rubbing and making similar sounds. Make sure you book it in in advance, and make sure you have it done. That is unless you’ve loads of experience of setting up derailleursnand gears.
buy spare inner tubes NOW and carry 2 with you always, along with a pump!
at home, take both wheels off and learn how to replace an inner tube on both front and back wheels. So much easier learning at home instead of when it’s raining by the side of the road.
practice taking your back wheel off, and putting it back on - again, learn how to do this at home. YouTube clips are great for this
keep the hills for a few weeks in when you’re more used to handling a fidgety road bike. Save clip in shoes for a couple of months for the same reason
enjoy
Not too worried about the bike engineering and handling. My bike was my freedom when I was a kid.
Work up the distance slowly; if you try to ride too far in the early stages all you’ll do is exhaust yourself and then not have the energy to ride the next day. I did that yesterday and won’t make my club ride tonight because of it.
Give yourself rest days.
Above all enjoy it!
And remember n+1....
Even if you don't get the full outfit, get some shorts. The padding for your bum makes a big difference in terms of not getting sore. The seams are also in good places, where they might not be on normal underwear. Seams digging in right where your bum is on the seat is not good.
You can do cycling shorts with a normal T shirt if you don't want the full mamil look.
I got back into cycling for a while a few years back. Stupidly I decided to get a bike and then try to ride the ten, or so, mile to work and back. Let's just say that at the time I was not fit. It was also not a flat route.
The first few times I tried it I was ready to puke after climbing the first serious hill. Honestly, I had to stop and just breathe and try to keep my food down for a few minutes!
It quickly gets easier though and I got reasonably fit quite quickly, in time I got fitter and lost a lot of weight. The sore arse is one of those things you just have to power through. My sit bones were screaming at me early on, but it gets easier, perhaps try a day on, day off until they get used to the saddle.
My biggest problem was the addiction. I've never been remotely athletic, I hate running and all forms of physical excercise except cycling and possibly swimming. Cycling is nice, you can get fit and enjoy a bit of the countryside at the same time. It's not hard on your feet/shins/knees like I find running to be. Technical downhill descents are exhilerating and when you're heading down a twisty route fast enough to keep cars behind you it just makes you want to do it again and again.
Within a few months I was riding to work almost every day. It was only ten miles away but I would often take a route which was over 17 miles long on the way in and a longer 33 mile route on the way home, I just loved it so much. On the days when I just rode the short route to work it was always a race to beat my personal best (I think under 22 minutes over a hilly 10.17 miles was best I could achive).
I really got into it in a big way until I was riding a bike worth many time more than my car was! I was riding organised events and I even had a British Cycling racing license at one bit! Oh and you need a "good bike" and a winter bike![;) ;)](/plugins/EmojiExtender/emoji/fb/3.gif)
I write all that having not swung my leg over a bike in quite a few years now. I should take it up again - my scales tell me I need to!
Turns out there is an H in Haych! ~ Sporky
Bit of trading feedback here.
Don't be in a hurry to clip in, it only really helps on the hills and when you do if your going to be riding in traffic id strongly advise MTB clip ins over road as the MTB ones are double sided and much easier to get into. Buy decent shorts DONT WEAR UNDERPANTS and get a decent helmet without a peak otherwise you'll ride into the back of something (been there!)
Invest in some proper clothing. Padded bib shorts for summmer or longs for winter. The dhb brand (Wiggle's own brand) is excellent. As above, carry two inner tubes, tyre levers and small pump in a saddle bag if you're venturing out further than you can walk back. Definitely get some proper shoes with cleats. The Shimano cleat system is great. Shoes are something you should buy from a shop - almost impossible to get a good fit with online shoes. Yes, you will end up with a mamil outfit - they're used for a reason - comfort. No need to plaster yourself with Sky adverts though, that's just for wannabes.
One can spend a lot of money on cycling gear but the budget stuff is still pretty good. From experience brands like Castelli and Gore are no better quality than dhb. And dhb do some really funky colours.
As for routes, try Cyclestreets app for cycle route mapping. Surely there's plenty of option of proper cycle routes in London, hopefully some well away from cars and HGVs!
Back in 2012 I responded to a dig from my wife that I was getting a bit 'porky' and started riding to work and easing off on the crisps and sweets.
Last year I completed IronMan Wales and I've just dropped £10k on a new bike.
I'm far from alone...
I find road riding unpleasant and dangerous due to vehicle behaviour and don't do it any more except to nip to the shops. But if you're determined, join a club, Dorking has one, Kingston does, there are plenty more.
Your bum will sort itself out and you will get fitter, just take your time and enjoy it.
