I'm having a ball with my HX Stomp going direct to the PA but I'm struggling with getting a decent auto wah effect.
I've been using the mutant filter but I'm not entirely happy with the sound and it's getting lost/cutting off in the mix. I looked at the MU-Tron III user manual and tried some of the suggested settings from that, but still find it lacking in the wah department.
Does anyone have any tried and tested settings that could help or maybe I should be using a different effect block?
I only need the effect on 3 songs in the entire set so I'm not wanting to bring/hook up a dedicated pedal.
Any help would be much appreciated.
If you're using this block I'd appreciate knowing your settings to give me a jump off point.
What i did on the FX8 was to have an LFO acting as a wah pedal, moving back and forth, then applying it to a proper wah model. It worked perfectly and sounded ace.
This is the main disappointment in Helix for me - Line 6 have been asked to add an LFO loads of times but continue to ignore it...
I will be trying the Tron-up, as well as the Throbber settings suggested by @Jota.
I'm wanting the effect that reacts to my picking and simulates the toe to heel sweep of my cry baby.
The Autofilter has got me the closest to the sound in my head so far, but I need to dig in to all the parameters a bit more to get it sounding how I want.
