Is this pre-done strat scratchplate shielding adequate?
Question for the guitar wiring experts on here - so I'm using this strat scratchplate for a build, and it has that kind of metalized paper shielding already applied. The body routing will be fully shielded with copper foil, and in the past I've also shielded the back of the scratchplate with copper foil (and got good results re preventing noise). But would it be a good idea to copper foil the back of this scratchplate, or will the pre-done shielding work perfectly well? Cheers for any advice! :)
  • poopotpoopot Frets: 9099
    It’s fine!... it’ll do the job.
  • MegiiMegii Frets: 1670
    Cheers @poopot - will save a bit of time and effort then. Reply much appreciated :)
  • ICBMICBM Frets: 73031
    And even better, the pickup wires are properly twisted as well, which is something you very rarely see.
    Excellent, all good then, cheers @ICBM :)
  • HoofHoof Frets: 498
    As long as that shielding makes good physical contact with something else connected to earth that's fine. Your pots casing will be pressed firmly against it when it's all assembled so the connection will be made there at the very least.
    Cheers @Hoof ; - tested the shielding with my multimeter, and in fact it doesn't seem to make a good electrical contact at all. It's like there's some thin film over the metal layer, which is odd, but...
     So, appreciate the good advice given above, but have decided to be sure of things and do the copper foil after all. Oh well, cheers again folks :)
    That's normal with aluminium. It doesn't matter because the shakeproof washers you will fit on the pots will bite into it and make a good contact.
    There's no point whatever in adding copper foil over the top, it's just a pure waste of material and effort.
    Ah, OK, my bad then - have to admit it seemed a bit strange, cheers again @ICBM :)
