Looks like it could take castors, might make for an interesting gig
https://www.amazon.co.uk/dp/B01N4S6VNW/ref=cm_sw_r_cp_api_i_pRkJDbK4N990A
You have to drill a big hole for them (my M8 ones needed an 11mm hole. Then you can fit them and pop in some feet like this:
https://www.amazon.co.uk/dp/B077B7JFRR/ref=cm_sw_r_cp_api_i_7SkJDb66FHE42
To fit the rivnuts you can buy a £40 tool or bodge it like this (the metal bar with the hole in it was key, I found - I used a bicycle chain wear indicator):
https://donstechnologyblog.wordpress.com/2016/02/25/diy-homemade-rivnut-tool/
Ideal for a skatepunk band.
