Probably both (*) - If the cab is 16ohm, then set the amp to 16 ohm, too. I'd be surprised if running it one 'step' off (8 into 16, etc) would cause any damage though. YMMV. <-- Typed that before seeing bandmaster's response - I'm not disagreeing with him.
(*) If you wire 4 speakers by putting pairs of them in series, then running the pairs in parallel, you get a combined impedance the same as that of an individual speaker. I would guess that your cab has 4 x 16 ohm speakers wired that way.
Bandcamp
Spotify, Apple et al
Many thanks lads for all the advice tho, appreciated muchly.
