Stiff Selector Switch
I bought a 3 way CRL Tele switch with spring action after it being recommended on here.
The switch is very strong and it takes a lot of pressure to change. That's good for stopping accidental switches while strumming which does happen on my other Strat but it's just a bit too hard, really have to put pressure on it which takes longer (still talking milliseconds).
Is there any way to alter the action and loosen it up?
  • ICBMICBM Frets: 74497
    It’s likely to be a combination of the spring strength and friction - try a little oil on the mechanical ‘notch’ part first. You can weaken the spring if you’re careful but it’s a no-going-back operation if you get it wrong and end up with it too loose, so I would only try that as a last resort.
  • FunkfingersFunkfingers Frets: 15278
    Sounds as if something is physically impairing the movement of the lever.
    Was the switch equally stiff before anything was soldered to it? Is it possible that a conductor wire has become lodged against the switch.
  • normula1normula1 Frets: 662
    The 3 way CRL I recently bought is pretty stiff too, especially compared to a typical 5 way, so it could be par for the course.
    3-ways are always stiffer than 5-ways if they're the same basic design, because the notches in between the positions are smaller on the 5-way.
    It definitely seems to just be the way it is rather than anything wrong with it or soldered to it.
    But at the same time it's a lot more extra stiffness than I'd think just the extra difference would cause.
    How would I go about loosening the spring?
    By stretching it carefully. *Very* carefully...
    I foresee myself breaking it lol.
  • Andyjr1515Andyjr1515 Frets: 3129
    edited November 2019
    Before risking stretching it, are you able to just unlatch the spring and try the switch?  If it's still stiff then it's not going to be the spring that's the problem
    Would that (red arrow) be the area to lubricate please? And would WD-40 silicone spray work? Or is it better to use some oil on a toothpick?
    IMG_7195.jpeg 671.2K
  • I would use grease. Apply in modest quantity between the wheel and the ridges in the metal plate. Operate the lever to distribute the grease along the ridges.
    The wheel and ridges switches never feel as positive as the CRL sprung type.
    There's more friction in a twin-wafer switch too, which doesn't help.
