Cleans were good (though headroom was not as great as the 50 watt rating might make you think).
The drive channel was heavily compressed and somewhat 'mushy' - almost Mk series Boogie-like.
To be fair, through a bigger cab, the amp sounded much more open.
These are old amps, though generally exceptionally well built - that said, I wouldn't pay more than a couple of hundred quid for one in good condition.
Oh - and the reverb tank seemed to suffer quite badly from induced hum, so higher settings, particularly at home were unusable.
Noise, randomness, ballistic uncertainty.
The other consideration is the fairly dark sounding drive channel - that would be unlikely to cut through well in a band-mix.
I bought mine to use at band rehearsals, so I didn't have to carry my 4x10 65 watt Music Man unnecessarily.
I never attempted to use the RD50 on a gig, as even in rehearsal I could tell it was close to its limits. Subjectively, the 65 was much louder. To be fair, it had a much bigger cab and four times as many speakers. There was less difference playing the RD through the 65's cab - but of course that defeated the purpose of buying it.
It was as nice little amp - with the caveats in my earlier post - but they do not 'defy phyisics' in the way (for example) some smaller Mesa amps, in terms of volume and projection.
Confirm for me - solid state clean channel, 1 12AX7 on the dirty side, and 2 6L6s in the power section? I've played a HD210 before and liked it a lot. Would also like a different voice to two Vox's.
The clean channel doesn't have a master volume (unlike the HDs) so 'edge of break-up' sounds only come from pedals or pushing the amp hard. The dark drive channel doesn't do these tones either - it has too much gain and not enough brightness for that kind of sound.
It will quieten down perfectly well for home use - though bear in mind my comments re: noisy reverb, if that is important to you.
The also produced a version with a 12" speaker which might be more usable - though I accept there isn't likely to be one for sale near you any time soon. These amps weren't in production for long, so they are fairly rare - though not necessarily valuable.
I would not pay that for a 34 year old amp. They are well made, but (assuming it has not been overhauled) every component is 34 years old.
Something like a Rivera Clubster or Mesa Express 25 could be bought for less, would be newer (and therefore at less risk of needing imminent repair) and more flexible.
MM amps are good - but you need to view it as an old and 'used', as opposed to 'vintage' when judging its value.
i shall report back!
