Am interested in a couple of cables with the vintage cable shown above. a regular 5m one and a 4m one with a silent jack. What's the process for getting a quote/ordering? Thanks.
Been uploading old tracks I recorded ages ago and hopefully some new noodles here.
Hi,
Please send me a PM and I'll get a quote to you.
Cheers,
R.
Eqd Speaker Cranker clone
If I didn't use a wireless unit, I'd probably make myself some of these.
R.
Custom coloured boots on these:
I wonder what the collective noun for patch cables is?
A matching pair with Silentplugs on one end:
Finally, a couple of speaker cables:
** New **
Semi-balanced leads
I am now offering "semi-balanced" leads, as used by a famous UK-based builder of elaborate fully custom guitar pedalboard systems.These are leads built with 2-core + screen cable, with one core for signal, one for ground, and the screen only connected at one end, typically the end you plug into your amp or effects.
As always, I use Neutrik connectors and Van Damme cable.
Typical prices are as follows:
Angled plugs also available (regular and SilentPlug).
I'm also considering offering PET sleeving as an option, ie. the whole cable sleeved in a protective PET mesh. Let me know if this is of interest.
PM me for a quote.
R.
Why, yes, I am!
Recently, I've been trying some braided sleeving and heatshrink for TRS stereo cable pairs:
I've also got a new label printer, and have been experimenting with cable labelling:
Of course, I'm still making guitar leads - here's one with a SilentPlug:
What can I make for you?
Send me a PM with your requirements.
R.
This is actually a case of bad terminology. The wiring scheme used is actually unbalanced, with improved shielding.
A balanced interconnect has three conductors: signal carrier, return-path carrier and a ground.
A non-balanced interconnect just has signal and return path.
A semi-balanced cable uses a signal carrier and a return path carrier in a multicore format, but also has shielding around this which is connected to the return path (usually only at the source end) to provide a form of active active shielding.
There's quite a good post about the subject here: http://stinkfoot.se/archives/2253
Bottom line seems to be that the "semi-balanced" cables have better noise rejection, but you'd only notice that in a particularly noisy environment.
R.
R.
I've done some two-cable short TRS looms for IEM connections on my PA. There's a pic further up the thread.
Drop me a DM with your requirements and we can discuss.
R.
