Replacing pickups on my Tele - how would you go about this?
  • FuengiFuengi Frets: 2850
    prowla said:
    That wiring ain't a pro job, that's for sure!
    I'm slightly surprised, it's a Burns prototype. Must have been thrown together for them from the factory. Either that or somebody has rewired it later.
    It's a cracking guitar, absolutely gorgeous neck and percussive tone.
  • ICBMICBM Frets: 73009
    Sadly, I would say that it is. It’s not even as bad as quite a lot I’ve seen...
  • p90foolp90fool Frets: 31918
    Just to throw a spanner in the works, I would also replace the lot, but I would be tempted to keep a push/pull in there as a phase switch.
    A single coil Tele bridge out of phase with a neck humbucker is a great combination, it cuts through but is generally warmer than two identical pickups.
  • RockerRocker Frets: 5022
    @sixstringsupplies will get you up and running in next to no time.
    Nil Satis Nisi Optimum
  • andy_kandy_k Frets: 828
    My train of thought on this was that a bridge single coil, will always be OOP with one of the coils in a neck humbucker, my interest in this was kicked off when I witnessed Bonamassa doing his BBE set at Newark castle, the led Zep stuff was incredible with his Nocaster, theres proof on YT.
    This,
    forgot how good it was.....
    https://www.youtube.com/watch?v=TuocThsJa0g
    Having 2 high power twins and 2 Bassmans full blast no doubt exaggerates the effect though.
    He absolutely has. Great to deal with, he's just putting a kit together for me.
    Not if it's wired right. The two coils in a humbucker are in phase with each other.
    (Apart from stacked 'single coil' humbuckers.)
    I always understood, coils in a humbucker were wound opposite-to each other, to cancel hum?
    therefore when a single coil is added to the mix-in middle position, it would be in phase with one humbucker coil, and out of phase with the other, which is what gives the slightly thinner tone-depending on which coil of the humbucker is OOP with the bridge single coil.
    It kind of makes sense to me, and also explains the series / parallel switches we all used to add to our guitars in the 80's.
    I had only ever tried stacked, or single coil sized humbuckers before this, and the Bonamassa gig got me thinking.
    Yes, the coils are wound oppositely, to cancel hum - but they are also opposite magnetic polarity, so the resulting string signals are in phase.
    Series/parallel makes no difference to phase, again if they are wired correctly.
    Stacked humbuckers are an odd compromise where the coils *are* out of phase because they are reverse-wound but share a common magnetic polarity, but work because they try to minimise string pick-up by the lower coil so there isn't that much cancellation.
    Fuengi said:
    Paging @ICBM @Roland @Funkfingers for advice on this birds nest! The cable from the humbucker appears to be a 5 core for some reason.
    What is that thing attached to the tone pot and why has it got two green things stuck to it?
    Can I wire this back up temporarily without the coil split? My new pickups are not going to arrive for a couple of weeks.
  • FunkfingersFunkfingers Frets: 14734
    Yes.
    Leave the red and white conductor wires from the humbucker soldered to each other. Insulate the solder joint.
