https://artistworks.com/guitar-lessons-paul-gilbert with 40% atm
Also did you sort out the Les Paul, what did BA say?
Flying with Virgin in the end - they've said I can carry the guitar through check-in to the gate. I've also got a full-on heavy duty flight case (and SKB case) for it, so it should be as protected as it can be....!
that will be sooooooooo cooooool
I'd be more worried about mandatory use of a slide, which I'm clearly far too stupid to operate...
... and why would I need one of those things anyway? I have a fully floating double-locking vibrato with a wang arm that I can't drop on the floor, so doesn't shatter, and I only break one a year if I'm gigging regularly and making too many elephant noises.... [Does not compute, can never have too many elephant noises!]
\m/
