Lockdown boredom - I fancy trying a Firebird neck in an LP special, but I’d like to do it in a way where I could return to stock with no visible mods ..the screw holes that a Firebird ring would leave rule it out (and I assume it would be too low anyway?)
I get that I can mount the pup in a Mini-humbucker ring, but can I make the Firebird pup height adjustable if the mounting screws go into the guitar body wood? (..short spring ‘above the pickup legs and longer spring below or similar?)
Whilst I’m at it, is there a good reason why I can’t find a Firebird with a buzz free neck?
Baz
https://www.ebay.co.uk/itm/111205780555
Instagram
