1. The strings are worn And incorrectly fitted
3. They need to be fitted properly (because this strings aren’t)
4. From l to r in your photo you should start with the thickest wirewound string at the left and move ast the thickness of the string diminishes to the thinnest non wire wound string at the right hand side
The guitar is a steel-string guitar, and it has a set of nylon strings on it - they are also fitted in the wrong order .
You need a set of steel strings, with bronze windings - if you're a beginner, I would recommend a set of 10 gauge (extra light) for now, they'll be easier on your fingers. If you need help with fitting them, don't be afraid to ask again, it's not totally intuitive if you've never done it before.
Look on the bright side, you could have got it the other way round - putting steel strings on a nylon-string guitar is a bad idea, if you're not very lucky it will cause serious damage to the guitar.
In fact, there is a reason I am now a guitar repairer... I did exactly that with my first - luckily very cheap - nylon string guitar, and it ripped the bridge off. Now *that's* a newbie mistake .
https://www.stringsdirect.co.uk/strings-c1/string-sets-c865/acoustic-guitar-c33/daddario-ej26-phosphor-bronze-acoustic-guitar-strings-11-52-custom-light-p205
I will change to steel strings, however, can anyone recommend a decent brand to buy.
Before you start stringing it, there is one big thing that a lot of people get wrong - the pins that hold the strings in do *not* need to be fitted with any great force. The idea isn't to jam them in so hard that they hold the whole tension of the strings - they're meant to push the ball end of the string sideways so it rests under the top of the guitar and all the pin has to do is stop it moving back into the hole. You should need no more than light finger pressure for this.
The ball ends should be where the five are in this pic, not the 4th string which shows how to do it wrong!
Kinking the ball end slightly before you poke it down the hole can help it move sideways as the pin goes in.
Even before that... if you can't get the pins out because they've been jammed in too tight, don't use pliers or any other tools to pull them out - you will chew up the pins and probably the bridge, or even break the head of the pin off. Instead, simply slacken all the strings, put your hand inside the guitar, and push the pins out from the inside - a coin or pick held on your finger tip will make it easier if they're really stuck.
