Tele bridge pickup tone control?
lovestrat74lovestrat74 Frets: 2676
What do you usually have yours set to? I see loads of demos and general YouTube vids on Teles and no one ever tells you what they have their bridge tone pup set to.
What's your default tone setting?
  • RandallFlaggRandallFlagg Frets: 14266
    Around "7" if full on is "10". Same with just about any guitar bridge pickup tone control.
  • JohnnysevenJohnnyseven Frets: 938
    Full up all the time for me.
    My trading feedback can be seen here - http://www.thefretboard.co.uk/discussion/58242/
  • lovestrat74lovestrat74 Frets: 2676
    What pup @Johnnyseven ?
    I have 4 Teles. 2 have Mojo Esquires, 1 has a Mojo Broadcaster and the other a Creamery Alt 88 A5 magnets.
  • Fishboy7Fishboy7 Frets: 2336
    Wide open. Or bypassed altogether (on an Esquire)
    :+1:
  • cbilly22cbilly22 Frets: 361
    One of the things I like about Tele controls is the lack of numbers. I find I actually use my ears for the best tone instead of thinking "bloody hell that's on 2!". Often makes me wonder if amps, pedals and guitars would be better off with no markings on them at all.
    Re the bridge tone control, probably about 6 or 7 at a guess.
  • HAL9000HAL9000 Frets: 10072
    edited May 2020
    About 7 for me, and the volume rolled off a smidge.
  • AlexlotlAlexlotl Frets: 186
    Middle it initially, then adjust to taste depending on pedals and amp. No numbers, so just do it by feel - suspect I usually end up on 7ish, but may push it in either direction or even bypass it.
  • chris78chris78 Frets: 10236
    I prefer to play with the volume rather than tone. Tone is always full. I can darken it up if I want by dropping volume back
