Can anyone chime in on sensible A/B/Y pedals
 I need one that lets you use 2 amps simultaneously and in conjunction with one another, ideally with a MIDI/CV controllable level for each signal.
“The TV business is uglier than most things.  It is normally perceived as some kind of cruel and shallow money trench through the heart of the journalism industry, a long plastic hallway where thieves and pimps run free and good men die like dogs, for no good reason.
Which is more or less true.  For the most part, they are dirty little animals with huge brains and no pulse.”
Hunter S Thompson
  • JalapenoJalapeno Frets: 6417
    edited May 2020
    https://www.andertons.co.uk/guitar-aby-pedal-guide covers all the ones I've ever heard of, and more
    Boss LS2 line selector covers oodles of options plus level controls.
    Feedback
  • KeefyKeefy Frets: 2382
    There’s probably a GigRig product that will do this but it will be spendy.
  • Mac44Mac44 Frets: 24
    how spendy?
    Hunter S Thompson
    GigRig spendy ? Roughly twice what others will cost ;)
    Feedback
    do they appear used often?
    Hunter S Thompson
    if i can do it id much prefer CV controlled levels, if there is a product that does that
    Hunter S Thompson
    What do you want from level controls ? Various different boost scenarios ?
    Feedback
    yup and remote level adjustment, to a fine degree
    Hunter S Thompson
    Volume or boost pedal(s) before/after ABY?
    Not sure they make what you're after tbh.  Earthquaker one has a built in 20db boost, but that's either on/off ....
    Feedback
    I need the signal kept pristine, so will pay for that
    Hunter S Thompson
    maybe 2 sensible volume pedals, but crossfades tricky...
    Hunter S Thompson
    Have a chat with Dan @ GigRig - he might be able to build you something.
    Feedback
    okay great - many thanks for the speedy info
    Hunter S Thompson
  • sweepysweepy Frets: 4218
    Boss ES range if the Gigrig G2 is too much although there is a G2 on eBay at the mo
  • SteveFSteveF Frets: 540
    Gig Rig do the ABYBABY - worth a look maybe (baby)?
