It might be difficult on a 7.25" radius board if you bend a lot, but it still should be close.
http://www.theboxwoodchessmen.com/
https://www.facebook.com/tingiants/?view_public_for=231700547508938
I'm not saying that it is the case with you, but years ago I just thought that super low action would be the best thing, but the reality for me was that other things also come into play.
If you can't do what you want on a 2mm string height at 22, it's not the string height that's the problem.
Some players do play very lightly and/or are more tolerant of fret buzz, but personally I wouldn't even try to get it lower than that.
Only if the reason it won't go lower now is because the bridge is bottomed out. A shim only adjusts the relationship between the neck and the bridge, it doesn't change how low you can get the action relative to the frets.
In fact, a shim can sometimes introduce a very slight up-turn at the very end of the neck, so it might be counterproductive if you're right on the limit already.
This.
Excellent info and advice as usual. Many thanks, I suppose I'll have to live with this action height.
Also, I endorse:
Check Yngwie's action some time.
My advice is not to get too hung up on action statistics. I have often found that guitars become more usefully playable after raising the action (or going up a gauge without adjusting the truss rod tension).
The other circumstance where this sort of set-up makes sense is for the Stanley Jordan two-handed touch playing approach. i.e. Faux Chapman Stick, low tension, low action, very stiff/straight neck.
I'm concentrating on playing Legato on this guitar and a low action at the higher frets seems to help.
Ebay mark7777_1
No, I never bend strings, not really my style, but I like players who do it well.
I managed to get the action of my Tele silly low, like under 1mm on the 12th Fret for the High E and about 1.2mm on the Low E. It does not buzz anywhere.
For the Strat due to the relief on the neck I can only manage to get it to about 2mm on the low E and 1.5mm on the High E on the 12 fret. In fact the saddle for the Low E doesn’t go any lower. So to get it any lower I need to straighten the neck more or cut the nut deeper. But I plan to put 9’s on it next time so it should be lower then.
Both are 7.25” radius.
