This is what I've personally found to work best for a med to hot bridge humbucker & lowish output neck (single or HB). Previously many of the inner coil/split combos I tried sounded too weak.
A - neck
B - neck + bridge (part split) in series
C - neck + bridge in parallel
D - bridge (part split)
E - bridge
In the diagram there is no connection for the neck inner coil wires on a 4 conductor humbucker so these would be taped off.
The bridge inner coil connections labelled green/white here can be reversed if things sound too thin or too fat in position D
Uses an Oak Grigsby/Fender super switch, not the Schaller (stock musicman type)
Heres a demo
Guitar has a firebird mini hum in the neck (Winterizer)
and a PAF (Fletcher w unorientated A5)
in the bridge
1 - neck
2 - neck + parallel bridge
3 - neck + series bridge
4 - parallel bridge
5 - series bridge
I’m not normally a fan of humbuckers in parallel, but this particular one - an Oil City Brassknuckle - sounds good like that.
This also has the advantage that all settings are very effectively hum-cancelling, more than if I’d combined both split pickups.
1. Bridge
2. Tapped bridge
3. Tapped bridge and neck in parallel
4. Neck
5. Neck and tapped bridge in series.
This is a timely thread because Oil City are making me a pair of Brass Knuckles, and I’m wondering which settings to use. It will be a 5 way superswitch, so many combinations are possible. My first thought is:
1. Bridge
2. Tapped bridge
3. Both tapped in parallel
4. Tapped neck
5. Neck
but then I’m asking myself whether position 3 will use the same coils as 2 and 4.
2nd gen rotary wiring (wired and later PCB variants):
- Position 2: Bridge humbucker with neck singlecoil, in parallel
- Position 3: Bridge and neck humbuckers
- Position 4: Neck singlecoil with bridge singlecoil, in parallel
- Position 5: Neck humbucker
