Does this guitar exist....
HootsmonHootsmon Frets: 16088
Gibson semi 336 size(ish) but with single cut and deeper ( but not 175 deep ) with center block?
PS not the LP with f holes job....that kinda idea though but a bit deeper than the Les Paul
tae be or not tae be
  • Winny_PoohWinny_Pooh Frets: 7901
    edited July 2020
    Maybe not, but you really don't need deeper.
    Single cut but 335 depth:
    Duesenberg starplayer
    Gretsch G5655TG Electromatic CB Junior
    Other Jr series like thr G6659TFM players edition jr broadkaster etc
    Gibson ES446
    Deeper than a LP hollow I estimate due to the arching but double cut: PRS Hollowbody
  • TeyeplayerTeyeplayer Frets: 3338
    Not deeper, but you might want a look at the Gibson es235.
  • dindudedindude Frets: 8574
    These although only made for a fleeting periods year or so ago.
    Also the Godin Montreal Premier
  • ICBMICBM Frets: 73179
    PRS Archtop - although the singlecut version only seems to come with a trapeze tailpiece, so I don’t know if it has a centre block. The doublecut one definitely does since it has a stopbar.
    They mostly seem to come with the piezo bridge but you can find them without.
    If that’s not quite right I’m sure @WezV could build you one :).
  • barnstormbarnstorm Frets: 643
    No centre block in those, but robustly built – he showed the construction in this video when the guitar came out. Thought it was a shame they left it as a Private Stock model with the blingy neck decoration.
  • EricTheWearyEricTheWeary Frets: 16454
    Probably something in the Guild back catalogue. The current Bluesbird is like an inflated Les Paul : slightly deeper, I think wider, chambered, no F holes.
  • FunkfingersFunkfingers Frets: 14834
    ES-125TCD, perhaps?
  • HootsmonHootsmon Frets: 16088
    Thanks guys  :)
  • NiteflyNitefly Frets: 4954
    You missed out on this one, Hoots (cos I snapped it up!), although it doesn't have a centre block...
    You snoozed...
