[Thread diversion]
All you’re doing is tightening the wrap on the post and forming the string to the bridge saddle etc. A good firm pull in the middle of the string will do that perfectly well - I do it as I tune up to normal tension.
If the strings are slipping on the posts, the ‘half back turn and lock under’ method will stop that completely. There’s no need for excessive string wrapping - that just means there’s more to have to pull tightly, which gives the impression that the string is stretching, when actually it‘s just the coil on the post tightening up.
no slippage or breaks. Give it a try.
Kahler Pro and Flyer vibrato string anchors are ideally shaped to tear the ball ends clean off strings during over-enthusiastic upwards bends. The (partial) remedy was to tin over the string end wraps with solder before fitting them.
Adam from D'Addario here.
It s pretty rare but as ICBM mentioned, it can occasionally happen.
If you have the issue repeatedly with various strings / brands I'd suggest trying our pre-soldered guitar strings (which were designed as this was a particular problem with some Kahler trems). As this has only happened with a couple D'Addario strings it may well have been a manufacturing fault.
Drop me a DM and I'll put it right for you.
Also, some really good info in this thread re string 'stretching' etc.
____________________
www.adamironside.com
www.youtube.com/Adji87
Shame as I really like the strings otherwise.... I've been using Picato strings for a while now without issue.
