At least the pickup switching is down for on, so you don't get the classic Jaguar problem
I built my first electric guitar when I was 17 - a sort of DIY Gibson Chet Atkins nylon-string solidbody - but I cheated... I used the neck and bridge from a broken classical guitar. (Broken accidentally by me not knowing the difference between steel acoustic guitar strings and nylon ones!) I made a new solid body for it and fitted a microphone capsule under the bridge as a pickup, since I had no idea about piezos then. It did work, but it wasn't exactly the last word in luthiery.
Sadly I don’t have it any more, I recycled the body for some other project later and I can’t remember what happened to it. It would have been nice to see how it sounded now.
Nil Satis Nisi Optimum
https://i.imgur.com/O08MizF.jpg
https://i.imgur.com/kEuBOye.jpg
Forum feedback thread. | G&B interview #1 & #2 | https://www.instagram.com/_harry_seven_/
*The neck profile is bizarre - very narrow and an almost perfect D-shape.
*After a wee polish, the frets are much better, but they’re a. Not the most even and b. Overhang the fretboard here and there - ouch!
*The controls just about work.
*Pickups actually sound OK, in a low-output, grungy kind of way.
*The machineheads are the wrong way round.
Until today this hadn't seen daylight for over 40 years.
I did gig it at least once. It really does need a new nut, maybe I'll fettle it while it's out. But how much should I change and how much should I leave as is?
Just as you would with an all-original ‘59 Les Paul
Okay just the nut, new strings and a setup then.
Things I noticed/remembered:
