PRS setup recommendations
myrmanmyrman Frets: 72
edited September 2020 in Guitar
I am looking at getting my P22 properly setup. Any recommendations for who could use preferably within 50 miles of Northampton.
  • Would Feline be close enough?
  • SteveRobinsonSteveRobinson Frets: 7343
    @Paul_C ;might be able to help?
  • myrmanmyrman Frets: 72
    @SimpleSimon ;Unfortunately not they are over 100miles away
  • 19791979 Frets: 91
    I would recommend Danny at Leicestershire Luthier. He has just refretted my Vela with jescar gold wire and it’s lovely to play. He’s really approachable so you should be able to get what you need
    Just checked out his webpage. He looks ideal so I will give him a call . Thanks :+1:
    No problem, hope you get sorted
  • I really rate Dave. He gets all my business these days
    http://davefarmiloe.com/
    In northampton too, in a place called woodford
  • TTBZTTBZ Frets: 3001
    Howard Smith in Leicester is really good too.
  • jeztone2jeztone2 Frets: 2161
    It’s worth it for any complex work though. He does the best refret work in the UK. IMHO. I live in Nottingham and I’ve yet to find anyone local that seems either technically competent or understands timescales. So for little stuff I tend to use Tim Marten as he’s only one train journey away. For anything a bit more demanding I’d still go to Feline and yes he’s 168 miles from my front door.
  • That's a good selection. Thanks all for the suggestions.   =)
  • Andy Viccars in Bletchley, Milton Keynes. Viccars Custom guitars.
  • FelineGuitarsFelineGuitars Frets: 11978
    +1 for Danny at Leicestershire Luthier - good guy!
    We built him a guitar too !
    If it’s the black one, I’ve played that guitar @FelineGuitars . It’s a beauty indeed
    He’s only a village or two over from me, will have to check him out next time I need some work doing.
    Good to hear that Dave is still going.
    He was the first luthier /repairman I ever took any work to in 1984 when he worked out of a small shop called Danda Music which was about 100 yards from where I am now.
    I had him ream out a Les Paul headstock tuner holes to fit a set of Schallers.
    Quick update. I ended up using Danny at Leicestershire Luthier. Very happy with the results and would highly recommend him.
