Going back to your other DGT and a tuning issue - My guess would be damaged/worn fulcrum points - The 6 at the bridge - can be easily damaged and cause such issues if not correctly set-up/adjusted - Only cure then is to replace the whole set and they are not cheap - As a rule, NEVER adjust them when the strings are at pitch - Better still NEVER adjust them as they should be factory correct and never need adjusting
By Parcelforce or by design?
https://i.imgur.com/D8rWSkQ.jpg
I've known some players/techs adjust these 6 screw fulcrum points, with a few to taking down the action a bit more if required - But often work carried out when the strings are at pitch - The PRS trem works well, but those 6 fulcrum points should be left alone unless you know what you are doing
