I am kicking myself for missing out on a BKP Nantucket P90 for £50 on ebay. I now need you all to say "phew, that was a close call because that pickup sucks, you really should buy... <<insert here>>.
From another thread, I mentioned the P90/humbucker combo apeing a Yamaha 611. There's a very classic Seymour Duncan SP90-1n paired to a Custom 5. I really like the sound of that although wonder if a slightly hotter P90 may be a better option and the Nantucket looked to fill the part. Not convinced I would buy new though to was thinking on a True Grit P90 or maybe Alegree Desert Dew? I'm fairly sure I want a UK built one though. Ideas please!
In all fairness the Gibson P90 is a pretty good pickup as well. My only other experience of P90's was in a PRS Mira 245. They were Seymour Duncans. In my opinion they didn't clean up too well when the volume control on the guitar was rolled back.
My suggestions are the Duncan Antiquity or an SP90-1N with one or two magnet swaps.
Strangely enough, Gibson usually manages to make a nice P90.
1. Gibson P90
2. Catwhiskers "Nantucket Spec" P90
3. BK Supermassive
4. Full Monty P90
5. PRS P90 (think its from an SE? Have no idea why I bought it...)
6. Humbucker sized Alegree Desert Dew
They are a little "polite" but respond really well to germanium and fuzz in general.
Core PRS guitars with P90s usually have Seymour Duncan SP90-1N and SP90-3N pickups. These have the black on white model ID stickers associated with SD OEM pickups.
Here's the pics of the P90 @Funkfingers
So that's an SD then?
The D-shaped cutouts in the baseplate suggest Korean or Japanese manufacture.
If you look at the bottom edge of the plastic cover in the upper photograph, you should see a fine moulding flash line, running perpendicular to the inner surface of plastic, across each rounded corner. I have the same detail on the Metric cover of a Korean-made P90 removed from a budget Yamaha guitar.
The "step" around the top edge of your cover is exactly the same as found on PRS SE P90s.
The braided screen on the output cable looks like the shiny, slippery stuff found on some Asian pickups. The PRS/Seymour Duncan braid looks and feels the same as on a Gibson. It even frays differently.
Finally, on SD P90 covers, the countersinks for the mounting screws are wide enough to nip into the edges of the polepiece screw holes
