"Has anyone ever played through a Tech 21 amp?
Seriously thinking about switching to a Trademark 60 for gigging - anyone tried??"
If it helps, he plays a variety of guitars - LP's, Tele, Gretsch Duo Jet - and tends to play either just on the cusp of breakup or just into slight crunch, with an EQ pedal for boost for solos, generally speaking.
I am slightly fascinated by the Koch Jupiter which is a hybrid combo with a more modern feature set than the Trademark and slightly cheaper - although not an SS modeller. There is one UK shop that sells them or, again, cheaper on Thomann. Apart from the word Koch in large letters IMHO looks better too!
He certainly doesn't drive the Mesa hard. As I say, he plays fairly cleanish - the dirtiest it ever gets is bit of crunch from a Tubescreamer or similar on a fairly modest setting.
I know next to nothing about amps, but I know enough to know an amp of that ilk must surely have a considerably more headroom than he is pushing it to. We're talking pub gigs, mic'ed up amp, so onstage levels aren't getting especially loud, plus he's one of those rare guitarists who knows that the volume knob goes down as well as up...
Does edge of break-up well, from recollection.
Would much prefer the Mesa though....
The West Midlands Boogie repair person would charge approx £50 ( plus valves if need be) if he took it to him, so if a set of valves is £70 then presumably a shop is charging him £80 for, well, some kind of administration fee on an unnecessary service.
It's light and loud and seemed well made.
The clean is awesome and does tweedy breakup really well. The drive chanel is alright but the weird shared eq makes it hard to get both sides sounding good at the same time.
I'd plan on using a pedal for drive and ignore channel 2 entirely.
It was loud enough to gig. It sounds like a small amp because it is but the Sansamp out will sound big into the PA as it's emulating a bigger cab.
I'd happily have another or the rare tm120 which has 3 independent channels
Don't buy a new one as they are cheap secondhand. Also consider the amt Stonehead.
Many thanks. I have passed on your comments on the Tech 21 to my mate.. The comments from @ICBM and others about his current servicing regime for his Mesa have also been noted, but I need to find a diplomatic way to bring that up with him!
Thanks all, great response
