I have a Vintage Les Paul with a Tonerider Rocksong pickup in the bridge. It’s classed as an overwound vintage HB.
I also have an LTD EC-256 into which I put an Iron Gear Metal Machine, this is (apparently) their highest output passive pickup.
Obviously they’re different guitars, the LTD has a thinner body, and it also has SLIGHTLY heavier strings (theres 11-54 on the LTD and 10-52 on the Vintage) but when it comes to distorted sound and output the tone of the LTD isn’t nearly as clear or articulate as the Vintage and quite simply doesn’t sound as good!
The LTD sounds slightly muddy ( even on the stock neck pickup too). They’ve both been well set up so it’s not an issue with that.
I’m using Bias FX 2 mobile to compare them so so everything is a similar as possible.
Am I expecting too much? I thought there would at least be some sort of difference in output between the two? Or is it less to do with the pickups and more to do with the guitars?
I used to have an EC-256 and Tonerider Alnico IVs opened it right up.
Been uploading old tracks I recorded ages ago and hopefully some new noodles here.
I reckon it's the pots/caps. I'm thinking of rewiring the guitar as the pickups are fine.
Can't say I've tried that specific pickup, but maybe an overwound Rolling Mill from Iron Gear might be enough output-wise for you (doesn't look miles removed from the TR Rocksong output-wise, with the added "bite" of A5 as opposed to A2)?
But also... it could definitely be the guitar (including the rest of the electronics) as you're not exactly comparing like for like.
Maybe swap the pickups around between guitars and see what that yields?
Enjoy! Rewiring guitars is fun once you've had a bit of practice
