The best I could do apart from that is a set of six which are about 11.5mm (the threaded section, which is what matters presumably), with the last millimetre being plain not threaded. I don't know if those would fit, of if you think you could file them down.
To be honest the opposite problem is far more common - not long enough for the threads to engage properly.
Thanks so much for checking. I've got some of those 11.5mm ones already. Cannot believe I didn't think of having a go at filing them down . Have some wisdom for that.
