Bar magnet pickups
Evening one and all.
I am looking at having a(nother) electric baritone ukulele made up, and I'm looking around for pickups.  As it will only have 4 strings, a pickup with poles isn't really going to work, so I'll need bar magnets.
I have an existing uke, that uses a Warman Firebird style.  Just wondering if there is anything else someone could recommend?  4 wire would be good too so I can split.  TIA
Vox 24, Variax 700, Epiphone Dot Studio (Cats Whiskers pups, custom inlay, custom pickguard), Gretsch 5238T (P90s/B3), Gibson Les Paul Zoot (rainbow), Gretsch 5135 PS, 'Graick' G2312TVR, BarileleBo (electric baritone ukulele G6199).
  • ICBMICBM Frets: 73049
    Electric mandolin pickup? I think the string spacing should be about the same, and if you do a Google search it turns out there are a lot of options! More than I expected.
    Half a P-Bass pickup is also sometimes used for mandolins... although they're just a single coil usually. Or use a Mustang Bass pickup with the coils side by side instead of offset like the bass.
  • enteeentee Frets: 93
    And then, whilst TRAWLING the net, I find these ... http://www.almuse.co.uk/ukulele_pickups.html
    Thanks for all the messages; keep them coming if you have other options  :)
  • Winny_PoohWinny_Pooh Frets: 7897
    I've used a Guitarfetish cool rails pickup for bass and it was great, would work here too.
